V6 Tilt and Trim Compatibility
Salty Tricks
I have a 1991 200hp Evinrude parts motor. Will the Tilt/Trim assembly from this motor fit my 1998 Evinrude 225hp?
Salty Tricks
Re: V6 Tilt and Trim Compatibility
The diagrams on the BRP site look indentical but I want to be certain before I swap them out. I dont have access to see the 91 motor right now to visually inspect if they are the same. Any help?
ezeke
Look at the the part numbers for each motor. If you click the magnifying glass, it will give the series of superseding OEM part numbers: http://shop.evinrude.com/
Salty Tricks
Thanks Ezeke
Thanks for that link. I was using the older BRP site that did not have the superceded numbers. Looks like I can go with what I have . Again Thank You
