v8 chyrsler swap to chev v8 ( exauhst Y)
candrive55
my transom shield exauhst holes are differant than my volvo exauhst y holes
one large and two smaller on the y
the shield has one large and one smaller to one side.
can any one tell me what y i need.
The chyrsler one toast
Don S
Re: v8 chyrsler swap to chev v8 ( exauhst Y)
Here's the problem the big problem. Volvo never used Chrysler engines, however, Chrysler marine did use Volvo drives. So looking up what Y pipe you have is impossible.
By some chance, do you have a casting number from your old y pipe?
candrive55
yes i do they are 2600858 have pics
third one shows some of the rot
Don S
Sorry, I have never seen a Y pipe like that for any Volvo, and that number is not like any Volvo numbers.
candrive55
Oh nooooooo. So that leaves me with having to get a new shield or getting this y fixed.
is cast aluminum easy to weld. And if so can i even use it. I guess the other v8 volvo y the one with the big hole and one little one wont work?? I doubt I can find a shield locally. would the numbers of the current transom shield help at all
Sad
candrive55
heres the numbers off the shield if it helps
pn 850676
7906
ser number 213811
Thanks
