Re: Vacuum on carbs 1 & 2 a lot more than 3... What gives?
I hadn't forgotten what you had said from an earlier post CharlieB. I just hoped it wasn't that. It is a switchbox ignition, not distributor. I replaced the stator after I had my initial problems because I realized the hack job someone had done on it. They had one of the low end windings to fail so they did away with it and the high end winding that was on one powerpack. They then jumped the other high and low end winding off of one powerpack to the other. Then on top of that, the wires leading to the rectifier were burnt up at the base of the stator. It has a new stator, rectifier, and trigger now. I will check what you said out though. Worth a shot.
Laddies, are you saying that the vacuum that makes the fuel pump work is derived only from cylinders 5 and 6 then? Sorry, but I am a little confused by the wording of your post. I have not pulled the fuel lines at idle to check pressure at the pump though. I have cranked it with the top line removed, but never actually checked the pressure. FYI though, I did run to the garage real quick to check and see before I posted this, the fuel pump is actually mounted beside carb 2 and I think I remember the vacuum holes for that run directly into the case. If that's the case then of course my pump is operating on vacuum from cylinders 3 and 4. If incorrect, let me know, I am still learning... Thank you both for the input.
