vales tapping upon starting after sitting after 1year is it caused by lifter bleed down
If the lifters don't pump back up after a short period then the lifters may need to be replaced or rebuilt.
The reason I asked to check the oil level was to see if it had gone up. It it went up then something leaked into the block.
baha cruiser
the motor has haft system heat exchanger antifreeze in block is clear no water in oil the motor has been replaced with a long block 3 years ago thank you for trying to help
GA_Boater
Does the motor have oil pressure? The lifters need oil pressure to fill them with oil and pump up.
baha cruiser
i started the boat to re winterize the other day facing the motor the right side was doing all the clacking,i let it warm up a little then pushed the idle up to 1500 rpm and the noise stoped on the right, a little while later the rear lifter on the left started clacking will leave over winter and see what happens oil presure is normal
