starcrafter65
Thread starter- Joined
- Jun 9, 2009
- 645
I have a 2.5 4 in line that I just purchased - it is from a 1968 Starcraft.
The previous owner had done a head and valve job and run out of steam. The motor is ready to be run again - and I just want a reassurance about valve adjustment. The "book" says go to TDC on #1 piston and tighten a sequence of 4 of the 8 valves. Says to tighten to intial compression on the lifter and go 3/4 more turn. Then go to TDC on #4 piston and do the rest of the valves.
The previous owner said more like - get it running and tighten as it is running to eliminate the "clattering".
I did what the book says - but it just seems like you are tightening the heck of them.
Anyone with real know-how on this procedure - I would like to get this close before I try to start them.
Thanks
Clark
Resto Thread in the Starcraft forum
Thanks
Clark
