I finally found some time to get the boat put back together last night after repllacing the blown head gasket(1989 Mercrusier 3.0L). I adjusted the valves by finding TDC for each cylinder, removing all lash and tightening down one full turn for both the intake and exhasut valves for that cylinder.
I bolted everything back up and fired it up but I have some rocker noise. Did I do something wrong on the adjustments? What's the best way to go about setting the valve adjustments? I know you can set them with the engine running but what's the proper way to do that? It seems pretty self explanatory but I don't want to take anything for granted.
One a separate note, how do you guys put a drive back on by yourself? Those things are a bear to get aligned and put back on!
