Velvet drive noise- Hey Bondo
elpaso
1986 32' Silverton twin 230hp Crusaders straight inboard.<br />Borg Warner 71c velvet drives. Drive oil clean, engines run<br />smooth. Total time 1200 ?<br /><br />Port engine - at idle no noise - drop in gear - you hear a "clunk" - clunk -clunk as shaft rotates - pick up rpm to 1000rpm noise stops.<br />Foreword or reverse, same noise.<br /><br />On sea trial, everything runs great, no noise, problem has been persistence for 30 hours. Transmission still running normal.<br /><br />I have heard this sound on other velvet drives, and found flexplate ( coupler) would have a broken spring or plate would be<br />cracked. Removed flex plate - appeared normal, except all<br />springs were loose. Rotated transmission by hand, everything<br />smooth, no noise.<br />Installed new heavy duty plate, rated for330 hp, fired her up.<br />Same noise at 750rpm stops at 1000rpm.<br /><br />Any ideas ?
Rickles
Re: Velvet drive noise- Hey Bondo
Check and see if your trans model has a new updated valve-body available.I just changed one out yesterday for a hard gear engagement or cluncking type noise.Went away with rpm.Hope this helps you.
snapperbait
Engine missing at idle.... Seen more than one where a slight miss from a poorly tuned engine will cause a driveline noise..
I Wish I could Help,<br />But I Don't Play with Inboards very often......
elpaso
Jerry<br /><br /><br />Thank you Bondo for the reply, I have watched your<br />answers on other questions. I have received 2 good answers to my problem. There is always someone out there that will help.
Capt Ken
Yeah, what snapper said. Whats happening is when the engine idles less than smooth, it rattles the planetaries in the transmissions. Don't let it go on for a long time or damage can occur to the needle bearings in them. Be sure you are idling in the 750 neighborhood. You can idle them higher but don't shift above 1000 rpms.
