Venting plastic fuel tanks?
CharlesW
What do most of you do about the vent on a plastic fuel tank when your boat is not going to be used for a week or two?<br />Obviously the same problem comes up with my second tank when I am not using it.<br />One of my concerns was getting water in the tank by having the vent open during rain or while running and encountering water splashing on the fuel tank.<br />When I closed the vents, the tanks expanded like a balloon which didn't seem to be a good thing.<br />I now leave the vents open all the time, but still worry about letting water in.<br />Do the vent systems have a check valve or baffle that will prevent the rain or splashed water from entering the tank?<br />The tanks in question are 2 Tempo, 6 gal, on a pontoon boat.<br />Charles :confused:
rickdb1boat
Re: Venting plastic fuel tanks?
On my old toon, I always left them open, just for the fact that they did expand alot in the sun. Never caused a problem in 10 years, so I would think it's OK to leave them open. ;)
Just Jed
Dito. I always leave mine open except when carrying. <br /> P.S. Also I never top my tank right up which helps avoid any leaking from slosh or expansion.
Fouled Plug
Ensign
CharlesW, an inline fuel seperator/filter is always a good idea (and not an expensive one) It ensures clean fuel and traps any water that might sneak into your tanks.
CharlesW
Fouled Plug:<br />Sounds like something else that might be worth looking into.<br />My first season with a pontoon boat and the outside mounted tanks didn't seem to have any water problems. Everything is so much different on this rig compared to my 1993 Chris Craft. My wife says I worry too much. :p <br /><br />Charles
rickdb1boat
Fouled Plug makes a good point. Ya never know!!<br /><br />CharlesW, My wife says that,too! :D <br /><br />If your really worried about it, leave the vent open and drape a small piece of plastic over the tank and secure it.
Luna Sea
I've had water problems before, in the gas. I used to put a heavy plastic cup/mug over the cap, that way it was vented, and I didn't see water around the vent screw threads everytime I opened or closed it...........
