Venturi Effect, definition:
A tube mounted in the water line so as to cause a restriction of flow. The constriction causes a change in velocity of water flow through the tube, resulting in a pressure drop at the suction port that is proportional to the flow rate. This negative pressure or vacuum can be used to pull water out of solutions tanks.
The Venturi effect is used in a carburetors jet. As high velocity air passes over the jet, liquid fuel is pulled out of the jet via the lowered pressure.
Well... my findings are that if your vessel is taking on water. And your bilge pump cant push enough water to counter the taking on of water. you can (and only when you are moving at high rates of speed while trimmed correctly) remove the drain plug in your bilge and water will be sucked out of the bilge by the lowered pressure of the moving water around the outside of the transom.
Agreed?
Agreed?
