Faztbullet
- Joined
- Mar 2, 2008
- 15,937
Re: Vernatherm removal good or bad idea?
No as t-stats rarely stick shut they mostly stick open....and motor has a check valve or poppet that opens at speed bypassing t-stat that why no pressure build up.What I don't understand is if the t-stat is stuck in the closed position doesn't the water sit in the water jacket and boil?
The reason you see a lot of ring failures on OMC engines are do to running to cold (bad/removed/stuck open t-stats) and the pressure backed rings. Incomplete combustion from running cold can coke up the ring lands and push rings into a port breaking them.Thermostats do nothing for a carbureted outboard like mine.
