Vertex vs OEM pistons
dandreye
Hi All,
Any opinions wrt quality of Vertex pistons compared to OEM? While looking for .015 oversize ones for my OB I've come across this one:
Just curious.
Thanks in anticipation,
Dmitriy
Faztbullet
Re: Vertex vs OEM pistons
It a very very good piston, have installed several hundred and never had a problem.
dandreye
Faztbullet:
Cool - thank you. I assume it's fully interchangeable with the OEM one e.g. it'll accept OEM rings of the same size if required.
Faztbullet
99% of all aftermarket pistons will accept OEM rings except Wiseco, which is the last piston you would want to use.
dandreye
The seller has just replied confirming it comes as an assembly together with the rings and stuff, which is what I was expecting.
Interesting why such a difference in price then ($70 compared to $100ish for OEM ones).
