Vertglas gel coat system
cpt ron jc
i have a 21 cuddy the jel coat needs att, vertglas system check it out does this stuff work ,has anyone tryed this out,i started compound and buffing im already tired of doing little sections at a time,the shine is comeing back but i have a long way to go,are there any short cuts, they claim there are a number of chem.that work.vertglas is one,i know jel soft scrub works also ,however y still have to shine later HELP TY for reading
rfdfirecaptain
Re: Vertglas gel coat system
Before I found this website I used Vertglas. Just last week I posted the final update on a thread I started where I got a ton of info from the guys about buffing out the gel. I don't think I will ever use Vertglas again.
Anyway, I had a 21' bowrider. I purchased a vertglass kit for about $75. It took me several passes with the scrubber and then with the polish coat, but it turned out really nice. From 100 feet back it looked showroom condition to me. The gel was a deep glossy maroon color. Before vertglas it was very chalky and always looked like it had a coat of white dust on it. :(
So yes, the stuff works. I kept my boat coverd and parked under a shelter. 2 years later is was needing a coat, but I let it slide. The third year I did it again useing the same kit. It took me just a little less work, but again it came out fabulous.
Again, after the results I got about following the instructions from these iboat gurus on compounding and buffing, I won't ever use vertglass again.
cpt ron jc
thanks rfd, so why won,t you use this system again if it worked,is you have to apply every yr,ty for the info.
rfdfirecaptain
From what I've learned in the last few weeks on iboats... I feel comfortable restoring (buffing) out my gel. Whereas before I was just looking for a quick and simple fix.... you know some kind of magic wax that breathes new life into it.
Yeah it worked, but back to what I said before... "From what I've learned in the last few weeks on iboats"... I would hate it if I ever had to buff that stuff off, if for some reason I needed to get down to the gel coat.
cpt ron jc
thanks rfd yes i thought about that also,must build up on coat,i enjoy working on my boat i might try another,coumpound i was useing west marine brand,i need something more agressive,presta is a good brand,what compound cuts through this haze best,i was also reading up on wet sanding first,my colar is comeing back its slow going,what compound do you use.
rfdfirecaptain
OH YES! Does it ever build up "coats". That's the whole principle of the product.
Wash, scrub oxidation, wash, first restore coat, second restore coat, third restore coat.
I used 3M see photo below I took just after I got started. You can see some of the rough results in the background.
cpt ron jc
t y rfd yes i was looking at the same 3m,superduty compound i will give it a try your boat looks good,what a dif,did y use a buffer to apply 3m or by hand,i have a 3 speed buffer.
paultjohnson
captn ron plz see my thundercraft pics/post
Yacht Dr.
As Cap tells ya now before and after...
There is NO magic wand with faded Gel restoration. Just Real hard work to bring back that ol shine.
I could make bucks relabeling a can of silicone spray with "magic fiberglass resto" .. but.. It wont last .. :)
YD.
