jayhanig
Thread starter- Joined
- Jun 27, 2010
- 836
My transom was replaced this fall and I'm now interesting in redoing the rear seats and engine cover on my stern drive since the vinyl is getting the worst for wear. There is just a wooden frame covered with vinyl... the wood appears to be ordinary pine 2X4s. The piano hinges that hold the engine cover on have seen better days and the board that they're screwed into has had numerous screws placed and replaced. That's why I want to redo this.... the wood is getting holey and the vinyl has hundreds of rust stains from carbon steel staples.
So, my tentative plans involve constructing a new framework using stainless steel screws and then recovering with new vinyl and stainless steel staples.
I am considering using plain pine as I worry about chemical reactions between PT pine and stainless connectors. But then again, I want to protect the wood from water. Resin? Polyurethane? What SPECIFICALLY should I use? I've got a Westmarine store within a reasonable distance.
I see no reason to reinvent the wheel and yet I'd hate to put a lot of work into a job that would have lasted longer had I just added a step or two. I have pretty good woodworking skills and a tremendous woodshop. What I know about working with fiberglass would fill a thimble.
Any and all suggestions are appreciated.
