Very good procedure for changing lower unit lube
KDAVID1
Re: Very good procedure for changing lower unit lube
Just finished per this procedure on my Merc 150--worked great--this was my first time doing the lube change and it worked great--one thing though--when you back the top plug out to let the air out but careful and not unscrew it too far (keep pressure on it) or it will blow out.
Enjoy.
water world
if you want to drain faster.after has been run. use lower unit pressure tester in top hole.
