cecho
Thread starter- Joined
- Jan 29, 2013
- 367
I had a bit of trouble trying to install the bellows when I did it the first time and I'm now thinking I may have done the job incorrectly the first time, so it looks like I'll be doing it again. Can the bellows be cleaned and reused or do I need to buy new ones? They are only about 2 months old. I thought it was good at the time, but now I'm thinking I may not have fully seated the forward side of the u-joint bellows. I did use bellows adhesive and I did let it get tacky before installing. I've done a LOT of reading on this subject and I think I had trouble installing it because it was tacky. I seen a few posts where people recommend putting the bellows on with the glue still wet for this reason.
The semi-constant whirring/growling/groaning noise is very slight and not always present, but a good way to get it to appear is after idling for a minute I put the engine to 2500 RPM while in neutral and after a few seconds the noise usually starts to appear. Only my mechanic's ear can seem to hear it. It sounds similar to a differential going out but it's much quieter and not as high pitched. The sound it is making also reminds me of a small high speed motor with bad bushings. The bearing still feels smooth, but since it's had water get to it for a second time I'm thinking it's now on its way out and should probably be replaced.
