- Joined
- Jul 18, 2011
- 18,867
After a few weekends of traveling around the country, etc, I finally got a chance to work on my boat :thumb:
So, I decided to install a VHF radio, since the boat did not have one previously. Here are a few pictures of the day . . .
I have noticed that other F-330's typically have have the VHF radio installed in the lower white trim strip of the instrument panel (right below the ignition switches). I purchased a Uniden VHF radio a month or 2 ago . . .
So, I did some measuring and it turned out that there was 'just' enough unobstructed room behind the panel on the left side to install the radio. After a couple passes of measuring I made the cut-out. and also mounted the microphone clip.
The radio fit into the opening . . .
Here is a pic of the radio set into the opening . . .
Next up was to do the electrical connections and then install the antenna . . .
