HorizonblueDK
Thread starter- Joined
- May 27, 2010
- 355
I have made my own thru-hull exhaust. It has been re-designed a few times. The way it is now, is silent outside the boat, at low speed. So I don't annoy any fellow boaters, when warming up the engine(4.3 V6) and leaving the dock. But inside the boat, is sounds like someone is holding a grinder against the hull. This noise appeared after I changed the design into what it is now.
My theory is that the exhaust pipes are vibrating, because the gas exits at the end of the quite long pipes, under the water. There is no vibrating when the boat is running on land.
This is what it was before, there was no grinding noise at that time, instead a lot of exhaust noise behind the boat, because the pipes are only half under water.
As you can see, I have also changed the swimplatform and the Volvo Penta 290 outdrive has been replaced by an SX.
So, what to do now? I would like to keep the thru hull solution, and have it quiet at low speed. That is the reason why I extended the pipes at a downwards angle, so the noise is buried under water. But I don't like the grinding noise.
