vibration issue
99seapro
I have a 2000 Johnson Ocean Pro 175 and last season developed a BAD vibration at slow speeds such as going through no wake zone. Idles well with an occasional sneeze while cold, but smooths out when warm. It runs perfectly when on plane. Any ideas as to the problem? Where should I start? I have run it probably 25 hours since it started and it persists. Could I be damaging further by running?
Black as
Re: vibration issue
Spin the prop by hand and see if your drive shaft is bent also check the prop for any damge
CharlieB
Re: vibration issue
How long since the carbs were cleaned?
Dirty idle jet or idle AIR jet can cause an occasional lean cough/misfire yet run perfectly fine at all speeds above an idle.
kenmyfam
Re: vibration issue
Is the prop in good shape and the shaft running true ???
99seapro
Re: vibration issue
I have only had this boat and motor for a year and have no clue when the carbs were cleaned last. The prop has a few minor dings in it but they were there before this vibration started. I know I didn't hit anything. I remember the day it started I put in some gas made a 15 mile run on plane and when I got to a no wake zone it started and hasn't gone away since then at low speeds such as 5-10 mph.
tashasdaddy
Re: vibration issue
i would start with spark and compression check, then prop shaft.
izoomie
Re: vibration issue
This may be a dumb question but have you run all the gas out that you bought when the problem started. I'm thinking bad gas.
robert graham
Re: vibration issue
The first thing to do is remove and inspect all spark plugs for an indication of problems, like carbon fouling, water leakage into cylinders, rich mixture, etc.
Good Luck!
tashasdaddy
Re: vibration issue
would you not do that, doing a compression and spark test????
99seapro
Re: vibration issue
tested the spark today and set the tester to the 20 mark which looked to be at least 1/2" and the spark jumped the gap consistantly on all wires. Didn't do compression check due to no gauge yet. All the plugs have a thin coating of dark brown residue that easily wipes away. Right now they're also very wet due to fogging oil. Also I looked in the plug holes and the top of the pistons are black should I decarb too.
