FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
would anyone be able to tell me why i have a bad vibration when i trim up? It will do it even half way up, but down it is fine? Just replaced gimble bearing,bellows, alined motor but still vibration. mercruiser 3.0 alpha 1
Half way up is way too high for trim, that is in the tilt range and it should vibrate.
If you are going by your gauge or where the trim limit is set, you might want to recheck the dimensions to see if it's adjusted correctly and you aren't trimming too high.
The picture below shows the MAX trim up dimension allowed.
when i had the lower unit off i checked the u joints they seemed fine not sloppy, lose or anything like that so i greased them up and put back it back in. So ill check the the other things you suggested thanks for the help much appreciated
