I got a 5 hp Wards with a Clinton motor. It hasn't been ran in years. I put ne fuel and impulse lines on it, a new carburetor, new plug fresh gas and it will not start when I put it in a barrel of water. It will fire and sputter, but will not take off. I have adjusted the carb to every possible setting with no results. I have checked the points, it has good spark. The thing that I don't understand is I was getting very upset and had it out of the barrel just mounted on my bench vise and pulled the starter it fired right up. I quickly shut it of and put it back in the barrel with the same results. It will fire and sputter, but not run. I took it back out and on my bench vise it will fire right up and run. I have broken and repaired two starter ropes, got blister between my finger from screwing with it. I'm about to do very bad thing to this little motor if something don't change. Please help me out if anybody can. I have been wrenching on chainsaws for 25 years and thought a two stroke is a two stroke, but this dang thing has me stumped.
