Re: Vinyl Top Restoration
Thanks for the thought dhatcher,
The weather is turning fall here and average 40 degree days are not far away. Unfortunately, any major painting to be done will have to wait until spring. I do however have tons of work left to do in the cockpit and in the cabin. I spent two years prior getting the mechanics, electrics and plumbing finished before the cosmetics started. If there is continued interest, I will post projects as they come along. Here is a quick run down of work completed thus far:
electric head, holding tank, elimination of overboard dump
complete rewire, addition of house battery, charging system, addition of lights, instrumentation, shore power w/panel and bilge heat, onboard charger, combiner, isolated house/start 12v systems, 12v breaker panel (ABYC specs as close as I can get)
carb rebuild, electronic ignition, exhaust upgrades, transmission rebuild, raw water pump rebuild, hoses, belts, addition of seacock, prop strut repair/ shaft alignment, shaft log and rudder through hull repack
Bottom job/ blister repairs (took awhile on this one) needs repaint w/ color change, 2 yrs old more to follow here
I am sure I am forgetting some stuff. All the work was and will be done by me. I still have plenty of projects to do. As most of the below decks work has had a good start I will be concentrating on cosmetics at least until the weather dictates.
I do not want to sound as though I am tooting my own horn here. I am by no means an expert in marine restoration. I do have a pretty good background but allot of the projects I have listed here were the first time for me. I am obsessive about research. Truth is, without the Internet, forums and people like you I would still be trying to get the thing in and out of the slip without damage. I have had allot of help. And I look forward to getting more from you folks.
Unfortunately I have not kept much of a record of the work that has already been done. I will however be covering the cosmetics as completely as possible. And of course I am more than happy to share what I have learned so far. Its been a barrel of fun, (and a truckload of money) so far.
Drew
