Visual temp warning
joita
Hello,
Is it possible to connect a light to the temp warning system. I have a 1989 mercruiser 4.7. It has an audible warning buzzer but some times, while running, the engine noise is too loud to hear the buzzer.
Thanks
BoatDrinksQ5
catfishcarl99
Re: Visual temp warning
just did this last week. $1.98 marker light wal mart. 12 volt in auto isle. works great.
Texasmark
Yes you should be able to pickup a 12v LED indicator light, or 12v any type of light and wire it in parallel with the buzzer under your dash.
For some more industrial style...
http://www.kele.com/panel-fabrication/pilot-lights-and-selector-switches.aspx
otherwise iboats has lots of different 12v light options! Great selection!
http://www.iboats.com/Marine-Indica...5343796--session_id.252724997--view_id.216654
If you are curious, the OT sensor grounds the cold side of the horn so hooking your bulb as mentioned will put 12v on one side as is on your horn, and when the sensor closes during an OT condition, ground on the other. Son had a boat with a dash light in addition to the horn.
Mark
