Re: VOID IN BOW FROM MOLDING PROCESS?????'S
Originally posted by Riddlers Ride:<br /> bet she can haul *** too huh
///////<br /><br />Glad to help. But you should probably listen to Jason more than me. har, har, har,,,<br /><br />He gives sound, prudent advice like your parents would. I'm more like your (evil) older brother that passes on bits of wisdom he's learned in reform school, or jail.<br /><br />Anyway,<br /><br />Thanks for the comments on 'POCO LOCO' (little crazy), or as many of my Hispanic friends around here have said, "No, it should be called, 'MUCHO LOCO'.<br /><br />Its a hoot. Tromp down on the 'Hot Foot' and it tries to turn your sunglasses into contacs.<br /><br />We're taking it out tomorrow. Hooty and myself will function check the new Stator, and play around with 3-4 different props & set ups on the tilt & trim to see if we can get it over 70 while keeping the Tach. under 6000.....with $1.75/gal. pump gas.<br /><br /><br />Here's something I've discovered that you might need to know on your project:<br /><br />If you switch over to the 'no-feedback' steering system, it locks down with a small clutch when you let go of the steering wheel. That way you can brace one foot firmly down on the gas pedal, the other on the dash, and it leaves both hands free to hang onto the cockpit walls as your sunglasses become form fitted contac lenses.<br /><br />Ed.<br /><br />Oh, <br /><br />Keep in mind that new boats are built by folks that will never own them.<br /><br />They build them for 'so many $ an hour', or 'so many $ each'. All they have to do is be able to sell boats.<br /><br />---------- sort of like fishing lures. <br />If you are in the Lure making business- you don't have to catch fish,,,, you just have to catch fishermen. <br /><br />The folks that build them will never have to fix them, or probably not even ride in them.<br /><br />They don't care how long they last, or how easy they are to work on.<br /><br />All they need to worry about is if someone will buy the darn thing after they've spend a few minutes doing what they do to help construct it.<br /><br />After that,,,,,, whoever ends up with it at some point in history is on their own.
