Volo Penta Won?t Start
trpfn03
I have the following engine:
Engine - 2000 model year - 4012033328 5.7 gsi pefs
The engine turns over but will not start.
Ran perfect last Monday when I docked it.
Fuel Pump appears to be working properly.
Just put on a brand new fuel filter and filled the fuel filter up with new fuel after I remove the new filter to ensure the fuel pump was pumping fuel. Removed and added fresh fuel to try to eliminate a fuel related issue.
Again-- turns over strong just will not start and ran and started perfectly the last time I used it (less then a week sitting)
Would appreciate any advice or check list.
Thanks a ton,
Kevin
trpfn03
Re: Volo Penta Won?t Start
Ran a few more checks-- still need some help.
1. Pulled plug-- looked OK-- little corroded on the exterior ? but did spark when shorted to engine riser
2. Changes fuel filter and tried to start
a. Confirmed full filter was full?try to confirm fuel pump is working
b. Removed new full filter again and filled manually with fresh fuel--- trying to test the quality of my fuel in the tank (note tank has been refilled twice)
Where to go from here?
