1216bandit
- Joined
- Aug 18, 2008
- 214
The volt gauge reads low...I checked voltage at the battery while running and it shows about 13.5 volts but the gauge shows about 11 volts. I checked voltage at the battery with engine off and it shows about 12.4 and at the volt gauge terminals I am reading about 10.5. The power to the gauges looks like they are daisy chained so I left the ground from the meter on the volt gauge and tested with the positive from the other gauges and voltage gets higher on the test meter as I move to gauges closer to the ignition switch. Would this indicate a bad connection at some other gauge before the volt gauge? Thanx! Dan
boat is 22' starcraft with a 4.3 mercruiser
