Volt gauge says 15 to 16 v, battery tests at 12v when running.
BudL1te
The voltage gauge on my Dash reads anywhere from 14 to 16 volts, but the battery across the terminals is only 12 volts. If the alternator wasn't working I would expect the voltage gauge to drop to 12 or below. Not sure where to start on this? Any advice? It's for a 1987 Sea Ray Mercruiser 5.7 inboard outboard.
dingbat
A fully charged battery wil run 12.6 to 12.7 volts
Isolate battery (pull positive lead off battery) from electrical system then measure battery again.
You may have a bad connection somewhere.
With motor running check voltage at alternator output. If that is higher that what you are reading at the battery, you have a bad connection somewhere
BudL1te
Decided to take the alternator off to clean the wires, seeing the orange wire Where It Bolts to the alternator was encrusted with rust. Got more than I expected. But at least I believe I found the problem.
BudL1te
Brushed everything down and was looking good till I noticed one of the terminals was loose, it fell off and no way to connect it back :( ordered new alternator.
