Volt meter hook up
Rich Novak
1972 SLICKCRAFT 225 HP STERNDRIVE
I want to add a volt meter to my current gauges.
Do I just run a wire from the + side of the gauge to the Ignition switch, and the - side to ground ??
Sounds to easy to me
Thanks, Rich
Don S
Re: Volt meter hook up
That is all there is too it. From the ign. switch I terminal to the + post on the meter and the - terminal on the meter to ground.
Silvertip
Honorary Supreme Mariner
way simpler to connect to the same "I" terminal and ground on the closest gauge. Do the same for the internal light.
