Re: volt meter/how to use
gee gee<br />You got some very good replies so I will just add a few things. Be carefull how you use your meter. If you set it to ohms or amps and hook it to a point with voltage can very easy burn up your meter. Not sure if your meter is digital or analog, but if it is not autoranging when mesuring voltage better to start with a high range and then turn lower until get a good reding. If it is analog when messureing voltage also need to make sure red lead is plugged into the + on the meter and the Black is ground or minus. Then always put you red lead on the more positive voltage and the black lead on the less postive voltage or ground. Have fun.
