I noticed a couple of the continuity cables were off on my outdrive. Could that have somthing to do with it?
Are you using a marine charger to charge the batteries? If not, THAT could be part of the problem Automotive chargers are not wired the same as a marine charger..
Not sure what you mean by this... are you talking about the bonding cables? If so, then YES it could have something to do with it, but it is NOT the CAUSE Of the problem. Someone probably took them off THINKING that it was a problem.
If you launch the boat like that you are creating a very dangerous electrocution hazard for anyone in the water near your boat, as well as corrosion issues for your outdrives and possibly anyone elses boat docked near you.
It could be an A.C. outlet wiring problem on the shore connection or on your boat. Need to get it figured out and resolved!!
