DudeAbides
Thread starter- Joined
- Jun 20, 2015
- 54
Is it normal to see voltage across the white wires from the ignition modules and ground?
I am getting 12-30 volts while the engine is running. 1989 85hp with presto lite ignition
Harness to helm is disconnected so I am trouble shooting by starting and killing the motor with a jumper at the terminal.
Motor is running better than ever since disconnecting the harness so I am sure there is a problem there to deal with.
I also had a situation where an ignition wires insulation was burned and likely shorting to the block. That's fixed also but wonder if the module
Is shot now from that?
