alley mechanic
Thread starter- Joined
- Apr 15, 2011
- 100
Ok wanted some input on this topic on a 98 evenrude 115 voltage regulator rectifier, i had to replace a voltage reg due to not charging at all i also replaced the stator as they say to replace both at same time. Well all was good when started up at idle it was charging at 14. 1 volts went to two tournments than it started charging at 13.1 volts i am using a duell purpose deep cycle battery load tested good ,so i started looking for info when battery is full does it continue to charge at 14 volt or does the voltage go down with amps also or does it stay at 14 volts cant find that information it says in the omc shop manuel that it is fully regulated if any body has this info it would be greatley appreciated ,than you advance alley mechanic
