TOOSTROKIN
- Joined
- Nov 9, 2004
- 42
Ok heres the deal. I finally found the firing problem on my 94 sport jet 90 when i replaced the stator. Fired up fine. Now it is not charging the battery. Volt meter reads 12.2 volts with motor off. After running a while with volt meter hooked up and about 4000-5000 rpm on the water no increase in voltage and actually starts to drop in 10-15 minutes to around 11.7 volts. Is there a test for the voltage regulator operation? Thanks.
