jluchuk
Thread starter- Joined
- May 20, 2008
- 43
I have a 2000 Larson 290 cabrio with 220 hp volvo penta 5.0 GL PEFS engines and DP-S duo prop out drives. I previously had a tread open on hard shifting and thought I fixed it but I am still having problems. The controls are Teleflex Morse SL3 top mounts with trim and push in neutral start. I have had problems with both hard shifting and the neutral switches sticking in so that when the throttle is returned to upright it will not shift into gear. I have had this problem occur on both the port and starboard controls. Several questions I have are: Do these controls wear out? A new SL3 costs $600 and I don't want to find out it isn't the problem. When the throttle is stuck in neutral I can take off the top cover and move the cable lever with a screw driver and the neutral switch pops out. I have taken them apart and cleaned and lubed them with no effect. The shift is still very hard as well. Can this be caused by worn out controls. My problem I don't know what a normal shift should feel like. When I disconnect the cables it seems like the controls are easy except the it seems very hard to move through the detent position. Would you recommend replacing both controls and cables? I found some Uflex controls that would fit the space but I don't know if these are any good and would they work. After it comes out of the water for the winter I plan to disconnect the shift cables to see on they move. If anyone can provide me any advice in this area I would appreciate it. Thanks. Jerry
