Volvo 2003 SX M Seal Replacement
mulholland65
Hi
I recently checked the oil in my outdrive and found it to be milky.
Drained and pressure tested and detected a leak at the shift seal.
Questions are
- do I need to remove the shift actuator housing to replace?
- can seal be replaced with basic tool .... fine screwdriver to remove and socket to seat home?
- does the drive need flushing prior to refill?
Help appreciated.
Steven
Don S
Re: Volvo 2003 SX M Seal Replacement
You have to remove the shift mechanism and disassemble it. to replace the seal.
A socket will work to drive the seal home, but it must be the same size as the OD of the seal.
If you Click Here you can download the OEM service manual. Look at pages 130 to 134 for complete details.
mulholland65
Many thanks Don.
Seals are en on order>
Steven
