Jim Marshall
Thread starter- Joined
- Oct 14, 2007
- 172
I am rebuilding a Ford 302/Volvo Penta 270 drive. It is in a 74 Glastron. I pulled out the engine, had it rebuilt, adding new seals and bearings to the Volvo housings. I am now installing the engine and housings through the transom with the two large rings.
My question involves whether a sealant should be used where the clamp ring mates with the housing. I know that the inner and outer rings seal but it seems like water could go in through the bolt holes and leak into the housing. Would form-a-gasket or silicone seal be appropriate where the clamp ring contacts the housing?
Any suggestions?
Thanks,
Jim
Any suggestions?
Thanks,
Jim
