Volvo 3.0 carb
gelee
Any one have any idea what CFM 2 bl this motor should be using? Checked the demon carb that is on the motor and found out it is a 500 CFM, seems to be a lot of carb for a 4 cylinder!
Don S
Re: Volvo 3.0 carb
Volvo has been using the 3.0L since 94, want to let us in on what model engine you have? Like full model or serial number. Year means nothing as Volvo doesn't list anything by year.
It's obviously a fairly new engine to have a Demon carb, if it's the original carb, and I would bet the engineers may have even given thought to the CFM in the process of designing it into the system.
gelee
Re: Volvo 3.0 carb
Don,It is in a 2009 FOUR WINNS,Having a problem with the motor running to rich at idle speed.Tried to set the idle needle jets but could not find a tool to adjust them.[will not take a small screw driver like a Holley needle jet]
Re: Volvo 3.0 carb
Ayuh,... It's probably the float level...
gelee
Re: Volvo 3.0 carb
Don, thanks for the info,will check it.
