Maverick16
Thread starter- Joined
- Jun 22, 2022
- 14
Not if the drive is off. If that video was shot with the drive off I would start with the drive belts on the front take them off run it a short time see if it goes away.Can the coupler make this noise?
I had replaced the mounts so they are good I give them a look thanksHow old is your boat? I had a similar sound on an old boat, that turned out to be rotten stringers/ engine mounts. The lag bolts were loose and the engine mount was slapping the glass fiber stringer covering. Hope that your issue is not that, but check the mount bolts just in case.
I bought a stethoscope best I can tell its from the back over the coupler housingKinda sounds like a timing chain slap to me. Get a stethoscope or a long screwdriver, ratchet extension run the engine and carefully listen to the timing chain cover, wouldn't be the first 4.3 with that issue
Could be a loose coupler or flywheel bolt maybe a loose flywheel cover or motor mountI bought a stethoscope best I can tell its from the back over the coupler housing
I does have a balance shaft.Well then your looking at pulling the engine to inspect the coupler. I would do a lot of double checking before I did that like listen to the area of the block on the back half of the motor and pull the drive and run it(you can adapt a hose to the fresh water intake hose) It would also be nice to now years and codes for that motor and if it has a balance shaft
It is 99.What year is this motor? Volvo stopped putting exhaust flappers in around 1999? What is your full model number?
What is your model number?It is 99.
