volvo 434a carb base gasket
brunolund
hoping someone can help me here. I have a ‘94 volvo 434A and i need a carb base gasket. it has a holley 4175. the gasket that came with the holley carb kit i ordered just barely covers the mounting surface of the intake. it is a single plane intake, which i assume is original. the carb number is 80552, and the kit was ordered for that carb. the base gasket that was on it originally was 1/4” thick, and way wider than the ones that came in the kit. one of the gaskets in the kit will work, but its 1/16 thick. I will try it, but does anyone know which 1/4” thick one i could order? the volvo site is not working for me right now.
You need an isolator gasket for a spread bore carb if your motor has a 4175
