AZChapBoat
Thread starter- Joined
- Jun 24, 2009
- 14
I recently bought a '98 Chaparral 240 Signature cruiser. It only had 360 hours on it & the previous owner said he filled up the gas tank once/year. It wasn't running above 3k rpm the first day I ran it but by the end of the weekend, after putting some hours on it, rpm's would periodically 'surge' and finally got up to running at about 3,500 rpm. I decided there were probably engine deposits and bad fuel in the system so I got some zMAX Marine Fuel Formula treatment & added to the tank the 2nd weekend. For the first 15 or so minutes with the throttle all the way down, the boat wouldn't go above 2k rpm but then just snapped out of that and was fine and ran up to 4k rpm and pretty well the rest of that day. Last weekend, the boat would not go above 2k rpm at all under a load but will rev full rpm's in neutral (so I don't think it's the throttle cable) no matter how long I ran it. Talked to a mechanic and he said it was running in engine protection mode, but this is the the GL which is not fuel injected & isn't supposed to have the protection mode. Temp & oil pressure gauges are normal and the engine sounds fine, except like there's something holding it back. Outdrive looks fine and props spin freely. Mechanic can't get to it for at least another week so this weekend I'm sitting at the dock if I can't find the solution. Since the problem started immediately after I put the fuel treatment in the gas tank, I'm thinking it could be a fuel system issue and should start by replacing the fuel filter and cleaning the carburetor filter. Any ideas?
