gverb1219
Thread starter- Joined
- May 21, 2012
- 22
OK, so hear it goes.
What it is.........
2002 Volvo Penta 5.7 Gi-A, ser# 4012059922 VP# 3869117, Closed Cooling system.
What it's doing....
Overheating AFTER coming off plane. Can run for hours at 3200 rpm...........slow down and within 30 to 40 seconds temp rises and alarm sounds. Overheated coolant flows out of overflow tank.
What I've done so far.....past to present...
10 months ago......
Overheating issue....exhaust bubbles in coolant tank......found bad head gasket.......had heads/valves done, new head gaskets, intake gaskets, etc....both sides
8 months ago.....
Overheating again....brand new manifolds, risers, installed new metal VP gaskets according to VP service bulletin.
Seemed to run ok......
Overheat again.......
Replaced cracked plastic hose connector between outdrive and transom shield that was allowing air intrusion...
Overheating again.....
Replaced expansion tank cap.....
Replaced thermostat.....
After a few outings now AGAIN overheats ....this time AFTER coming off plane.......
Removed and tested expansion tank...no leaks, good pressure, good water flow.....
Removed and replaced engine coolant circulator pump.......
Installed clear reinforced hoses on raw water pump according to the VP Overheat Pamphlet posted by Don (RIP)
NO Air Intrusion found.
Pulled suction side hose off RWP....it sucks....
Pulled outlet side hose off RWP at expansion tank fitting.........water flows good....more flow with increased rpms
Pulled RW hose off expansion tank to exhaust manifolds.......water flows good....more flow with increased rpms
Backflushed all hoses..........all clear
Backflushed hoses from exhaust manifolds.......through expansion tank.......water flows good dumping from outdrive.......
Removed/replaced raw water pump impeller anyway.....(piece of mind)
I have about replaced everything on this engine related to "cooling"...........yet it still overheats.........
I can run it for hours and the temp gauge stays in the 170*-180* range (closed coolant calls for a 170*t-stat), but as soon as I slow down for the no wake zone, or slow when I get to my destination.............temp climbs to 200*+, alarm goes off, coolant overflows from tank.....
I am completely baffled..............as are the mechanics I have been in contact with..........
Now, for something I thought interesting............
Just yesterday I spoke with a service guy who was on the phone with a "certified Volvo-Penta mechanic".
He asked me what kind of manifolds did I use when I replaced them?
I said I used Volvo risers and GLM manifolds from Sierra....I got the risers brand new at a great cost from a wholesaler........but they didn't have manifolds so I got the GLM's because of the HIGH price of VP manifolds.....
He said........"That's your problem"
REALLY.?????????
If ANYONE can help I'd REALLY appreciate it................I'm at my wits end here............
What it is.........
What it's doing....
10 months ago......
8 months ago.....
REALLY.?????????
