Hi guys,
I am in the process of winterizing my '93 Volvo 5.7 stern drive. My manual shows how to drain all the water from the block and the drive, but a Volvo fresh water cooling kit was added on, which the manual does not account for. This summer (when I first bought the boat), I filled the fresh water system with 50/50 antifreeze and water, so it's good for winter. What I'm not clear on is what I need to do in order to drain the raw-water side of the system. I see via the manual that there is a drain plug in the drive, but I'm not sure what to pull in the engine compartment to ensure I drain the raw water but not the fresh-water system. Attached are a few photos.
Photo one (engine overview) shows what I believe is the heat exchanger on the left side. Hoses to/from the coolant reservoir lead to that, however it looks like a hose from what I believe is the raw-water pump (second photo) also leads to the heat exchanger.
Is anyone able to offer some guidance as far as what I need to do to drain the raw-water system? I'm guessing pulling the hoses off the raw-water pump is required, but do I need to drain manifolds etc? Anything else I need to do with the heat-exchanger?
Thanks!
-Harrison
Thanks!
-Harrison
