Volvo 8.1 nightmare
jgerardi
Yes i bought the Diacom new. I am using the 94024 adapter. I am choosing EGC 2006-2007 (serial connector) is the system type.
muc
"Retired" Association of Marine Technicians...
Thanks,
Ok --serial
If you haven't already, it would be a good idea to use the Diacom "utilities" and check that your cable version it up to date.
You can use the compression test feature in Diacom to disable your fuel and spark while you are testing to find the voltage drop.
jgerardi
Im getting ready to put the boat back in the water for the season. (not that there seems to be much point since im just outside NYC and Covid19 has everything here at a standstill)
I am finding the Volve 30W full synthetic oil to be harder and harder to find and more and more expensive as well. My manual also says i can use 15w30
jgerardi
My last post should have read:
I am finding the Volvo 30W full synthetic oil to be harder and harder to find and more and more expensive as well. My manual also says i can use 15w30. Any thoughts on this?
muc
Full Synthetic • 10W40
• Ultimate protection from wear and corrosion (exceeds FC-W Catalyst specifications)
• Easy cold weather starts
• Higher oil pressure
• Better high temperature protection
• Direct replacement for earlier SAE 30W Synthetic oils
The 10W40 can be mixed with and is compatible with previous Volvo Penta SAE 30W synthetic engine oil.
Part Numbers
FULL SYNTHETIC
GASOLINE ENGINE OIL cATALYTIC CONVERTER APPROVED
sae 10w-40
21681794 Qt.
21681795 Gal.
21681796 5Gal.
jgerardi
Hey, once again thank you so much. I hope you're doing well with this whole mess we are in.
