volvo aq125a 1983
surfsup1
oil from engine goes in to carb. Oil is coming from tube on side of carb. The other end is on oil trap on the side of engine block. I have to remove the tube from the carb so the engine runs. The oil still comes out of tube is. any help out there?
HT32BSX115
Re: volvo aq125a 1983
Howdy,
Is that a question or a statement of fact?
You're going to have to be a little bit more specific.
captmello
Howdy,
Definitely a statement of fact.:)
Welcome to Iboats. Lots of AQ125 owners on this forum.
How much oil are we talking about. If its an oily film, it could be coming from the breather tube from the engine, blowby.
I don't know where else it would come from.:confused:
Let us know what you find.
surfsup1
Sorry i should had put a ? mark. The oil is coming from the tube on the side of the carb, the other end comes from oil trap on side of block. It is a lot of oil. It fouls the plugs. I have to remove the tube so the engine runs. Thanks for any help!!!!!!!!!
TowRoper
oil trap? do you mean the fuel pump? some pic's would help if ya can.
PiratePast40
The breather is supposed to vent gasses from the crankcase. It sounds ike you're getting quite a bit of blowby. Running with the tube disconnected probably isn't going to hurt the engine any further - just be a bit messy. A compression test will most likely tell you how bad the rings are.
surfsup1
Yes it has a oil trap just like that. I think it could be my rings Thanks for your help
bruceb58
Check your compression and possibly do cylinder leak down test. Will tell you a lot.
surfsup1
The compression reading is from 150 too 135 is this bad or good?
captmello
Book says compression should be 146-174.
If all cylinders are between 135 and 150, you may have a slightly tired but very runnable engine.
Can you clean the oil trap? I've never worked on one.:rolleyes:
I would consider replacing it. Maybe its clogged up and not functioning properly.
surfsup1
Put new oil trap on still have oil. thanks for your help!!!! I do not know what to do now. Could pluged up oil fliter do this or oil pump?
surfsup1
re-checked compression with good battery. Now have 150 on all four cylinders. When i plug the blowby tube, oil comes out on bottom of distributor, where it bolts to the block. Is this good or bad? thanks for any help.
PiratePast40
If the oil is trying to come out the distributor shaft, it sure sounds like it's excessive blowby. Your compression numbers for that motor aren't terrible but the observation sure sounds like bad rings.
captmello
by plugging the vent your not allowing the pressure in the engine to escape. Now its escaping through the distributor hole.
You don't have too much oil in the motor, do you?
