Volvo AQ125A Leak
Hawk Eyes
I just replaced my impeller on my AQ125A. It overheated so I check the impeller and its seated with the key. While doing some reading on "air leaks", I got the idea to put water down the strainer. After doing that water started to drip from behind the water pump. I was wondering if there is a seal or something behind the water pump that I could have damaged or moved something when pulling the old impeller out.:eek: This was my first attempt at changing the impeller in this boat.
captmello
Hawk Eyes
Re: Volvo AQ125A Leak
Thanks for the welcome,
I pulled the pump and checked the rear seal #12 on the breakdown. Its very stiff and worn. I pulled the shaft and assembled the pump together with shaft on bench. I filled the pump with water and its leaking from that rear seal. I will call the boat shop and order a new seal this week.
Thanks for the pic. Captmello. I will let you know how it all turns out.
Have a safe and happy Independence day.
Hawk Eyes
Ok I know this was a while back but got it fixed. It was the seal on the back of the pump. I pulled it out and it just crumbled. The spring inside the seal was even rusted and falling apart. I rebuilt the pump and its running water like I'v never seen before. I wonder howlong its been sucking air.
Thanks for the pic, it did help in the parts searching.
