volvo dou-prop ?
osborne looney
girlfriends daughter just put $$$ down on 09 glastron 255 with volvo drive ? any issues with duo-outdrive one should be aware of ? i know cobra's are not so good--but i know NOTHING about the volvo set up ? thanks i-boat members
Speakrdude
Ensign
Re: volvo dou-prop ?
Is crap.....run......
(just kidding)
One of, if not, the best one out there!
TilliamWe
Banned
Check for corrosion on the drive. VP has had trouble same as Mercruiser with the Bravo 3. Especially if it has stainless steel props. As with Mercruiser, I would imagine removing the props and checking the rear bearing carrier would be important. Also check out the power trim system. By 2009, * I think * VP had moved the pump outside the boat, in the transom shield area.
