I have a Volvo 8.1Gi with a douprop outdrive.
I need to know if the oil change pump that I used for my Alpha 1 outdrive will screw into the oil drain/fill hole on the Volvo in order to refill the drive with oil.
I always changed my own oil on the Alpha, and this is the first year for the Volvo. I understand that you fill it from the bottom (like the Alpha) until it comes out the top screw under the shift plate cover. I'm not exactly sure why they need a dipstick as well, except maybe to check it throughout the season.
Anyway, to sum up, are the threads the same on both drains, and will a standard pump fit in the Volvo? (Because it appears to be recessed)
I should also mention that the boat is a 2003, and the drain is behind the props.
Thanks!
(BTW: I spent about an hour searching the site, and couldn't find an answer... Sorry if someone asked this question recently, I couldn't find it!)
Thanks!
