volvo inboard transmission shift problem
b smith
i have a volvo bb-225 b inboard engine with a vs transmission that takes about six seconds to engage when put into forward gear.does anyone
know what parts i might need to correct this problem and what the
cost might be.
thank you
CATransplant
Re: volvo inboard transmission shift problem
Does this have a Borg-Warner V-Drive unit, rather than an inboard/outboard drive? If so, I think you're looking at a problem with the hydraulics. I'm afraid that's not my area of expertise. I hope someone here will be able to help.
Don S
The BB225B uses either the MS3(B,C,D) or the MS4A transmission. Which one do you have. No such thing as a VS transmission by Volvo.
b smith
have volvo inboard transmission ms3b that itakes approx six seconds
to engage when put into forward need to know what to do to correct this problem and approx cost to repair.
thanks for any replies
Don S
Is the oil level ok? Any water in the gear lube? If not either of these, it's probably a slipping cone clutch in the transmission causing the problem.
Only fix is to remove the tranny, dissassemble and inspect and fix as necessary.
