volvo penta 130 4cyl with 270 leg
rudy abbott
i have a bayliner explorer 26ft with a volvo penta 130 4cyl 270 leg from the early 80s and just wondering how fast it should run? it runs at about 7mph and wondering if i increased the pitch of the prop would it go any faster? just feel as if the engines revving its head off and going nowher. any advise is appreciated thanks
Re: volvo penta 130 4cyl with 270 leg
Ayuh,... So what rpms is it turnin',..??
rudy abbott
ill find that out, as i think my rev counter is broke, its not showing above 1000rpm any ideas with that or will i just replace it?? thanks
Don S
That is about all that boat will do. It's not a planing hull boat, it's a semi displacement hull.
26 ft is a lot of boat for a single 110 hp engine to push around.
7 is actually a little slow even for that boat, they usually run in the 10 and 14 mph range. If you used the boats water pressure speedometer, they are far from accurate at the slower speeds.
rudy abbott
how does the duo prop work? could i fit a dou set to my 130 with the 270 leg? do i need a bigger prop shaft? if it could work any idea which set i could get? or am i just waisting my time with this idea? thanks
Don S
You can't use a DP with a 4 cylinder engine. Not enough motor to spin 2 props, besides, there isn't a gear ratio for the 4 cylinder engines either.
PiratePast40
Would be a good idea to check the prop and make sure it's not spun the hub.
denniskennedysr
I have the same boat with a AQ125-A four cyl. 115 hp. I have a 15X15 LH prop and at 4200 rpms with two adults on board my GPS will show (at best) great conditions 17mph. I have found that my trim position matters. I have to keep the bow down to get this speed and still keep control of the steering. I have had one of the old Explorers off and on for over 25 years. Great economical weekend Cruiser but here is a hint, the name of my boat is KNOT SO FAST:)
1983/2670 Explorer
AQ 125-A 4cyl.
Volvo Penta 270
