Re: volvo penta 170 overheating
Peter,<br /><br />Thanks for the advice. I think I will give it a try. I just bought a new (to me) 2003 pick up truck, and after the initial break in period, I had the oil changed from regular to synthetic 'cuz I read somewhere that the wear with Mobil 1 and equivs was so much less than with regular motor oil.<br /><br />Your caution about the older engines gives me a LITTLE cause for concern, because I'm thinking that anybody who would over look putting both seals in a water pump might not have changed the oil as often as he should have. There could be more sludge in there than the average engine, but I guess I'm thinking the less wear and tear and the cleaner the better. At least now I know I have to lay down cross ways in the engine compartment to put in the oil filter on the starboard engine, rather than leaning over the top of the engine, so I can clearly see that there's only ONE rubber seal in place!
<br /><br />One of our local yokels here suggested a pint of ATF in the mix for a short period of time to help clean things up too. Ever tried that? Do you think it would be wise in an engine that's had water contamination for an unknown period of time? When I took off the oil filler cap and looked down into the valve lifter space there, I did see some some evidence of rust. Just don't know how extensive it is throughout the rest of the engine. I just don't know if I trust these local guys working behind the counter at the local auto supply store, you know?<br /><br />Anyway, you can bet I'll be watching out closely for the double seal trick from here on!
<br /><br />Again, Thanks for all your help. I'm sure I'll be getting back to you with still more questions!<br /><br />Tom
