Re: VOLVO PENTA 280 propeller shaft replacement or straighten
The shaft does not play a role in setting the shim value on this particular lower unit.
You can change a 250/270/275 or 280/290/SP single prop propeller shaft without any change to the gear pattern.
This is because nothing will be changed re; the relationship between the driven gear/slinger pump impeller/angular contact bearing/shims/carrier housing "shim stop" shoulder.
All he needs is another 280 prop shaft.
Pull the bearing carrier from the housing, loosen the bearing plate fasteners, remove the entire prop shaft assembly.
Next..... remove the spanner nut, remove the bearing, (the slinger pump can stay on the gear), and remove the "driven" gear from the shaft.
Replace all of these on the new shaft in the exact some order and with the same shim pack (behind the angular contact bearing).
However, the same carrier housing must be used.
The gear pattern will remain identical to what it was prior.
Other than for the spanner nut, no special tools are required.
